054 clutch
Old 01-28-2005, 03:40 AM
slikts2000's Avatar
I'm not sure, i know its defo from 00-01, but i have been told that some 02 have it, not sure myself, mines an 00 so i know i've got one...
Old 01-28-2005, 03:50 AM
Shiskine's Avatar
Been watching all these clutch threads with some interest. I get a bit of clutch buzz on overrun between 2000 and 4000 rpm. To be honest, it's not a ballbreaker, but as my MY02 is two months away from its third birthday (although I have warranty cover through until July 05), I have thought it would be nice to go into year 4 with a new clutch.
However, did I not read on one of these threads that someone had had their clutch done with less than brilliant results? It's a pretty major item and I guess if it's done badly, you could end up with more problems than a mildly irritating buzz.
Right now I'm thinking that when I put it in for its 27,000 mile service, I'll mention the clutch buzz and see if the stealer bites ...
Shiskine
PS. Remind me again; do MY02s have the 54 or 55 clutch? Is the problem confined to the 54 (if yes, why do I get an occasional buzz) or does the 55 have similar issues?
Old 01-28-2005, 04:22 AM
GSi
GSi's Avatar
They all - 055 clutch included - buzz / vibrate under load from 4000ish down to 2000ish. But the 054 - when hot - was occasionally VERY noisey.. if you heard it you would think that something was seriously seriously wrong, even though it isn't.
If you can get someone else to listen to it, they can tell you if it's just a normal noise, or actually a replacement candidate.
Old 01-28-2005, 04:27 AM
MunkeyBoy's Avatar
ahh, this is probably the case with mine.
It was very noisy once on the way to Le Mans last year, probably due to the 'spirited' driving!!
how can i check i've got a 055 clutch?
Old 01-28-2005, 04:41 AM
GSi
GSi's Avatar
Take it out and read the part number?
I would expect Honda could tell you the VIN range of cars with the 054 fitted. But even though they could, I doubt they would.. If you call them up they will probably either give you a vague answer (stopped in June 2001 for example) or specific info on your car.
There is a thread all about the clutches somewhere on here - Turtle/Brian - provided quite a bit of info a the time, including the production dates IIRC...
Old 01-28-2005, 05:17 AM
little Chris's Avatar
Any one know the labour costs to change the plates? Also are the plates very heavy? Reason I ask is I'm thinking about getting the 55 plate from the US.
Old 01-28-2005, 05:30 AM
GSi
GSi's Avatar
I think you have to buy a kit rather than just the plate... if you battle with the search engine, you will find...
Old 01-28-2005, 06:55 AM
markcu's Avatar
My my01 had the 054 clutch in when I brought it, but honda swapped it for the 055, to be honest I think it's worth doing even if you dont feel its a problem..
My car came back feeling like a new car. The gear change was superb after the new clutch was put in.
M.
Old 01-28-2005, 08:16 AM
GSi
GSi's Avatar
Mine did too, but I think thats more down to the change of fluid than the clutch changes..
keungkeung69
05-16-2010 06:32 PM
CaymanS2k
05-03-2007 09:48 AM
desert tortoise
03-24-2003 04:20 PM
yogi
12-02-2000 07:54 AM
Quick Reply: 054 clutch
