weird noise from rear right
Got this weird rustling noise from the rear right. Ive had a hub go out and it sounds completely different. I jacked up the car and checked the wheel, and there was no play. Its a pretty quiet rustling. dont hear it above 50 mph. I can hear it when im speeding up or slowing down. sounds like a fast rustling, but im pretty sure it kind of sounds like it slows down the slower i go. If im rolling up to 10 mph i dont hear it sometimes. Any guesses? Also i dont know if its comin from the wheel area or if its something from hardtop.
Sounds like it might be a wheel bearing from the description. I assume you've done the wheel nut tightening, if not it would be a good time to check that as well.
https://www.s2ki.com/s2000/topic/920...heel-bearings/
My bet is on the wheel bearing in conjunction with scoring on the hub. You are probably going to have to replace both. If your hub has scoring and you put a new bearing on it, you will be replacing it again shortly after...I learned the hard way.
i replaced the bearing about 6-8months ago...so i learned just as u did i guess....how much did it cost you, and where did u take it?
