Need Help - Dash Warning Light
![](http://www.autolablibertyville.com/wp-content/uploads/2013/07/airbag-warning-light.jpg)
EDIT: SOLVED
Hi guys, I could use some assistance. The airbag light has popped up on my dash after re-installing my seats (removed to install seat covers). I'm pretty sure it has to do with the wiring for the seat sensors. Does anyone have any experience fixing this problem? I would appreciate any advice, or if you have a chance to check out my car it would be a great help. Thanks in advance.
I plugged back in what I unplugged, as far as I could tell. I had it cleared via an OBD II, but the light came back on shortly after. Thanks for the suggestions.
I believe the owners manual discusses this procedure. This thread discusses the whole procedure and includes a link.
https://www.s2ki.com/s2000/topic/897...tor-srs-light/
![](https://www.s2ki.com/forums/images/s2ki/ranks/com_organizer.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
yep you have to reset the srs system you will need to make a jumper wire and locate the connector which is yellow with 2 green wires. you can find the sequence on the forum make sure you have plugged both seats in
![emot-tip-wink.gif](https://www.s2ki.com/forums/images/smilies/emot-tip-wink.gif)
Thanks to everyone for the helpful suggestions! Special thanks to tegu for inviting me over to give me a hand. In the end it worked like an NES game, just blowing on the connectors and re-seating them did the trick.
