Help: Engine Stall
Help: Engine Stall
Just started my 03 AP1. Rpm was flutuating up and down and so I shut it off. I restart the car but it didn't start. After a few tries, I gas it a little and it start. Now the car can't stay above 200 RPM. After about 5 minutes, Check Engine Light came on. What is the problem?
Just being paranoid, I just brought in my car to Lute Riley Honda about 3 weeks ago for the TSB on the Window regulator under the warranty. Now warranty is out, what could be the problem. Car only has 7000 miles
From what i am understanding it's might be the MAP or the IAC. I had the same problem while i was running with dual ram-air intake(ones of the ram-air ran directly straigh to the intake manni causing the IAC get dirting real quick) my rpm would be bouncing up and down at 2000rpm when in neutral. I had talk to Billman(handyman on under the hood forum) and he told me it's my iac. And so i cleaned the iac and it work like a charm. Try to do the MAP-WHACH and take out your IAC and clean it with WD-40 and see from there.
But like Cosmo had say....it could be vacuum leak somewhere. Try to re-tied all of the vacuum holes and check your coolant. If you need help on how to clean the iac or map-whach then let me know. I think i am getting pretty good with taking the iac out after so many times
Well, the first thing i did was to blow the MAP and up to now, still not functioning. RPM stay around 200 and wouldn't go up. Plus the light inside the car stay pretty dim.
[QUOTE=fastcar@9k,Mar 6 2007, 06:02 PM] Ran the car with Code P0113 that said intake air sensor temperature is hight than expected? and also P0505 for idle control system malfunction?
THanks Viets2k. So far so good, I did do more research and basically reset the ECU and then ran the car all the way to the redline. Next, i let it sit idle to relearn the RPM. So far so good. No check engine light, RPM back to normal. But I thought Honda Car are reliable?
