clutch help please
clutch help please
My clutch pedal keeps going from hard to soft in between shifts. Also when i shift i have to let my clutch almost all the way out before i can give it gas or itll over rev. This started having ever since i replaced my clutch.
I had an aftermarket clutch and flywheel but replaced it with an oem one. I have replace the master cylinder and clutch line as well.
Any info would help guys thanks in advance
i was having a weird time shifting at one point, and it was cuz my floor mat had gotten wedged up under the pedal, so check that, then check the clutch fluid level and report back
Originally Posted by CosmosMpower,Jun 23 2010, 11:05 PM
Check the clutch fluid level, bleed the air out of the line.
If you just had it all replaced, i would bleed the entire system.
i bled the entire system completely out multiple times already and fluid is nice and clear and full and doesnt seem like theres a leak i think the next place i would look is the slave cylinder thanks.
I know masterforce was having this same problem. not sure if it was ever fixed
