Texas - Houston S2000 Owners Greater Houston Area S2000 Owners
Solution to the vibration I had at the TWS...
Old 06-10-2002, 12:03 PM
Unicron's Avatar
8/29/02 - Update:
It turns out that it was my inner driver side cv joint. It has some pits in it. Here is a report with pictures:
https://www.s2ki.com/forums/showthread.php?...&threadid=78994
6/10/02 - Original thread:
Remember how I had to quit a day early at the John Eagle TWS?
I was complaining that during a hard curve to the right...I was getting a thumping vibration?
Thanks to this board...I can narrow the problem down to damage on one of the cv joints.
Persons on the board say it's most likely the inner cv joint on the driver side.
https://www.s2ki.com/forums/showthread.php?...?threadid=66007
I will see in the next few weeks if John Eagle Honda can help.
Old 06-10-2002, 12:05 PM
DSF_S2k's Avatar
This is exactly the same problem I am having. My car is at JEH as I speak.
Dale
Old 06-10-2002, 12:19 PM
Unicron's Avatar
Dale,
I dropped my car off at JEH the week directly after the TWS...and they could not duplicate the problem.
They really couldn't start ripping stuff apart on my word.
Maybe I'll take one of their service persons for a spin? I need an aggressive right curve to show them. The vibration can be felt slightly during acceleration.
How did you duplicate the vibration to them?
Old 06-10-2002, 02:53 PM
DSF_S2k's Avatar
Mine is not at the vibration point yet. It is simply clicking when you accelerate from a dead stop. Apparently the clicking is the on set of the vibration, or it could be the spline's. In anycase it needs to be fixed.
Dale
Old 06-10-2002, 03:56 PM
Insomniak's Avatar
i've been getting the clicking sounds.. (not diff.. i only have 4k miles and no drops on the new one) think i need the cv joints too
Old 06-10-2002, 06:15 PM
DSF_S2k's Avatar
Ill keep you aware of what the outcome is. It may be that the splines just need some grease. We will see.
Dale
Old 06-10-2002, 06:37 PM
Wesmaster's Avatar
Are all of y'all under warrantly? If not, a new axle will cost around $450...just fyi. Start taking your lunch to work.
Old 06-10-2002, 06:39 PM
DSF_S2k's Avatar
[QUOTE]Originally posted by Wesmaster
Are all of y'all under warrantly? If not, a new axle will cost around $450...just fyi. Start taking your lunch to work. [/QUOTE
Im still under factory warranty (got 10,000 mi. to go) then Im under the 100,000 waranty
Dale
Old 06-13-2002, 10:30 AM
Unicron's Avatar
[B]Are all of y'all under warrantly?
Old 06-13-2002, 01:08 PM
Wesmaster's Avatar
Originally posted by Unicron
I checked out your car...it looks close to being done.
Cool man.
Did anyone look at your axle or did you just drop it off?
Quick Reply: Solution to the vibration I had at the TWS...
