Texas - Houston S2000 Owners Greater Houston Area S2000 Owners
OIL - Where to find?
Old 08-17-2004, 02:04 PM
motokichi's Avatar
Thumbs up OIL - Where to find?
Hey folks,
So, what are you putting in your cars for
1. Motor
2. Trans
3. Diff
I'm thinking of replacing MT and Diff oil, I have seen threads recommending Redline and LE products, but can I get this stuff anywhere around Houston?
Thanks,
k
Old 08-17-2004, 03:06 PM
AP1_rock's Avatar
Castrol 10w30
GM Synchromesh FM
haven't changed yet
Old 08-17-2004, 03:09 PM
fly_S2K's Avatar
This is my current set-up.
1. Redline 10w30
2. Redline MT-90
3 LE 607
For the tranny I suggest trying out different fluids and seeing which one you and your tranny likes. I strongly suggest GM Syncromesh Friction Modified. That is going to be my next tranny fluid. I really like MT-90 but sometimes it's really notchy. Other then that it's awesome when it warms up and I don't grind anymore. You can buy redline fluids at the s2ki marketplace and the LE diff fluid and syncromesh at www.hardtopguy.com. I have found that hardtopguy.com has better prices for the tranny fluid and LE oil than s2ki marketplace. Hope that helps.
Johnny
Old 08-17-2004, 03:13 PM
AP1_rock's Avatar
..and you can find the GM Syncromesh Friction Mod. at any GM dealership. Just make sure you ask for Friction modified.
Old 08-17-2004, 03:20 PM
fly_S2K's Avatar
To add to what Dustin said, if they hand you a bottle of friction modified additive, tell them that's not right. That's what happened with me at Lone Star Chevrolet. They handed me regular syncromesh fluid and a small bottle of Friction modified additive. That additive is for clutch type LSD's where the friction of coefficient determines when the LSD engages/disenagages and IS NOT meant to be used with the tranny. They looked at me funny when I told them there existed a GM Syncromesh Friction modified tranny fluid untill they searched it in their chem book. I have the part number somewhere on my desk, but I can't find it at the moment, when I do, I'll post it up.
Old 08-18-2004, 05:41 AM
Ulrich's Avatar
Can't go wrong with Castrol.
Of course I might be biased.
Old 08-18-2004, 07:25 AM
motokichi's Avatar
Thanks for your responses. Maybe if we go to the same dealership for the GMSFM they'll eventually catch on and know what we are asking for. I read the thread on the trouble that people have had in getting the right bottle.
Johnny: The S&H kind of killed the marketplace idea, i'll check into hardtopguy.com. Did you need a pump for the LE-607?
To Ulrich: Does Castrol make gear and diff lube too?
Those of you that said Castrol for your engine, are you using GTX or Syntec?
The floor jack came in yesterday so I might try something Sunday.
k
Old 08-18-2004, 08:08 AM
AP1_rock's Avatar
i use GTX - no synthetic for me
Old 08-18-2004, 08:50 AM
fly_S2K's Avatar
k
If you're really trying to get a hold of redline fluids, I know pro-am on richmond also sells Redline fluids.
As for your question about the LE-607, nah I don't use a pump, but what I do is I leave the LE607 in a bowl of hot hot water prior to the fill. Then you use some fuel/coolant/oil hoses and stick it on the spout. I just squeeze the fluid into the tranny/diff. Just remember DO NOT use the same hose for the tranny/diff. The diff fluids usually contain chemicals which corrode our brass syncros, so keep that in mind and use seperate hoses. Hope that helps.
Johnny
Old 08-18-2004, 08:53 AM
fly_S2K's Avatar
Also, if you didn't already know, you'll need:
Motor- 6qts
Tranny- 2 qts
diff - 1qts
of fluid
Quick Reply: OIL - Where to find?
