Help! with fuel injectors
Originally Posted by tlogic,Feb 7 2009, 03:37 PM
I'm in the process of replacing my fuel injectors. I bought some AP2 fuel injectors thinking they would fit on an AP1. Will they? or do I need to buy AP1 fuel injectors?
As for the injector harness/connector, I cannot comment. If they do not fit the connectors (I believe they are the same), you could just get some AP2 connectors and wire them in.
ah, I see what the problem is now. I compared pictures of the fuel injectors I bought to the ones I have. Apparently, the ones I bought were from an 07. Well, this sucks...
Does anybody know anyone who's getting rid of their ap1 fuel injectors?
I'm having that rough idle issue on my car.
Troubleshooting = replacing coilpacks, sparkplugs, etc.
Does it sound like the motor is mis-firing? Has anything changed recently? When did the symptoms show up?
I have the same symptoms as the guy who made the thread. The car drives perfect except when I idle, I can hear 'poot poot' sounds coming from the exhaust. It's not that bad but it gets very irritating at times.
It doesn't sound like the motor is misfiring. Although, I do get engine lights say I have misfire but they come out random every single time. The things I have changed recently were air filter and spark plugs to try to fix the problem. The symptoms have been going on for awhile now.
http://forums.s2kca.com/archive/index.php/t-13916.html
Do a compression test/leak down and report back.
Also, could you post up a little more information about your car (Year, mileage)?
