GLUE REMOVAL
GLUE REMOVAL
I recently discovered that my 2001 S2000 only had a S2000 badge on the driver's side - the other one was missing totally and appears to have been removed at some time as the are is clean and looks good.
I removed the remaining one, but now have some serious glue goo there I need to remove. It is really thick and I was wondering if anyone else has removed emblems and if so, how did you get the mess off under them? The badge came off just fine with the dental floss technique, but the glue is thick and I need it off. Help?
I used goo gone and a blow dryer to soften it up. Honestly, anything you use will still require you to manually ease the glue off with your fingers. It's a pain and took nearly 3 hours to do both sides. Be careful with using your nails, it will scratch your car.
If you can find it, get 3M all purpose adhesive remover. It's not super gentile on paint (You'll want to use a paint polish and another layer of wax afterwards)but you hardly have to do any rubbing.
