Battery Replaceent
Battery Replaceent
My recently purchased '91 is needing a battery as it is slow to crank and I don't want to be left stranded somewhere (like 40 miles away from home at work). How can I replace it without losing the radio? No idea what the code is or how to redo it when the battery is replaced. Is this a take-it-to-the-dealer job (I hate to overpay for a battery). Help someone?
mike
mike
mike
mike
-Trung
Correct, only it's $97.50. They pull the radio adn then give you the code based on the radio's serial number. Heck with that.
Not all that wowed by the stock radio and now looking seriously for a decent replacement. Not a bigtime audiophile here. I drive 45 minutes to work and want to listen with the top down (99% of the time).
Need some help here. Who do I go to on the west side who really knows radios? I want a replacement, at lest some rear speakers (and maybe the pods), but definately want somethign that will use the stock controls on the dash. Can someone either help, make suggestions, or hook me up with someone who won't try to overdo me? COuld sure use some help here.
Ragtopguy
I have an older Alpine with a dash control interface (so the stock controls will still work) that I need to sell. The installation will be a straight swap.
So if you are interested, shoot me an e-mail. Oh, I an in the NW Side of town (290 and 6)
- Alpine CDA-7894 w/remote
- Modify DCI
- Wiring harness preconnected
- Radio Bezel w/ DCI IR LED already mounted (custom)
7894 -- that's the US equivalent of the model that I have (only that I don't need that DCI contraption and can actually use an original Alpine controller ). Good unit. Get some rear speakers from Lucid and you're set without paying an arm and a leg.
Stratocaster - Can't get the email to go to you. Want to know mre about the radio for certain.
Did get the stoker put back together. Super easy remove and got all the data off the back of it. Called McDavid and the service desk guy gave me the code. Worked fine, so I'm back with the stock radio.
Stratocaster - email me, please and let's talk. Likely going to add the lucent rears and may be a good idea to upgrade the radio. Gota keep the dash controls is all.
audio tech on west belfort....the guy is down to earth and has great prices, will even give you ideas on what you can do....im planning on getting 1 10inch sub (dont want the trunk to rattle too much) and replaceing the stock speakers inside
Originally Posted by Gutter,Jul 17 2006, 03:39 PM
honda charges $70 or so to give you your radio code...thast what i heard
Anyone have their stock radio they swapped out and aren't using? Later model, like an '04 or '05, maybe (mine is a '2001)? Lucent guys tell me there is considerably more output there and if you have a stocker that has been replaced and is taking up space somewhere, pm me. Not a lot of bucks here at the moment. Let's talk. Think I'm going to replace the head with a later one (if I can find one reasonable) and replace the front speakers and add rear ones. Current setup is bad overall.
