wierd noise
wierd noise
this noise is very stang it has been going on for a while and i havent had that much time to fix it and i dont know where it is comming from. i think it is comming from the front right and it is a clunking sound and it only happens when i am going forward and i stop, and it only does this if the car has been sitting for a half hour or so. i am confused and if anyone elts has had this happen plese let me know how to fix it.
thanks
thanks
have you checked to see if there isnt anything getting caught up with the spindle or any parts that are loose down there... u may want to start checking that...
i also have a very faint noise in my car, sounds like something is winding down when i depress the gas then when i accelarate it goes away... dont know wut it is...........
On the clunking noise, check the CV joint. They tend to do that when you shift the car weight onto the axel (weight to front when braking or to the rear when accelerating). A bad CV joint can also clunk during a turn.
If you got an alignment recently or any work on the car, double check to make sure all of the bolts were properly tightened on the suspension.
