Rear Brake Pad Replacement Tool?
#21
Originally posted by cdelena
There is a tab on the back of the inside pads that fits into the piston slot. I assume it controls the rate of rotation.
BTW, I have the piston tool but still find my old screwdriver is better for turning in the piston.
Rear Brake Pads - Inspection and Replacement:
Step 14: Rotate the caliper pistion clockwise into the cylinder, then align the cutout in the piston with the tab on the inner pad by turning the piston back.
The pic shows a tab on the rear of the pad being aligned with one of the four possible locations on the piston.
Hmm, so now it's not 100% clear to me how the parking brake works....but the diagram shows a cable attached to a lever, which is attached to what they're calling a cam. So it looks like yanking the e-brake rotates a cam, pushing the piston out. That jives with the picture I see. Maybe oversimplified, but that doesn't require the piston to rotate.
#22
You can pick up the piston tool from pepboys. It's called the brake piston tool.
Even with that and the master cylinder cap opened, I found it pretty hard to rotate the piston, esp the left rear one... but it works with a lot of uhh, duhs, and ahhs... Anyone know of an easy to rotate the piston?
#23
If it won't rotate easily with the tool - then either you've got the wrong tool or you have a very serious problem with the caliper and it needs a major rebuild.
On the tool, the little cube works with some calipers... but it wouldn't work here. Calipers across car lines ar every different.. so I settled a long running problem by buying a kit of the tools with a large number of fittings. Now I can do any rear calipers.
jyeung528
05-09-2005 11:12 AM
