Help with Rotors - SA
I'm buying new rotors soon and want to learn how to do them myself, can anyone help me put them on and I'll throw a couple bucks your way. Thanks
Make sure you have an impact screwdriver (the one you hit with a hammer) to take out those two pesky screws on each rotor. Be careful not to snap the tip on the screwdriver bit.
I was just going to say this. Sears sells them. I opted not to use one and had to drill out the screws after multiple drill bits and screw extractors broke. On a side note, if a screw extractor breaks into the screw be prepared for hell to get it out. Especially if it breaks off in the center.
I have another trick to get the screws out.. haven't broken or stripped one in over 20 years. I take a thin center punch to the middle of the screw, one good hit with BFH, screw comes right out.
Another broken tip occurred when I was helping my dad replace the rotors on his MDX. I ended up making two crossed slots with a dremel tool and took a new impact bit to it and got it removed. The two key things I can tell you about an impact screwdriver are (1) if you start to see the bit twisting, stop immediately and replace the bit before it snaps off and (2) buy the impact screwdrivers from Home Depot or Lowes that have a lifetime replacement warranty. You will eventually snap one of the tips off (keep the receipt too for exchange but I don't think it's required).
Serious questions, could you elaborate on how exactly that works? How does a center punch remove the screw?
Chris, its a little physics I guess. The screws freeze because of rust, dissimilar metals, heating and cooling cycles of the brakes..etc..
So when you give a good hit, its actually driving the screw deeper into the threads, and although maybe not seen with the naked eye, twisting as it follows the thread pattern, therefore breaking itself loose, and making easier to unscrew..along with WD40, goes without saying. Make sense? Furthermore, an impact driver is a funny tool along the same lines..how can you hammer something IN, AND out at the same time?
Another little known fact about rotors...other than the countersunk holes for the aforementioned screws, there are two other threaded holes in the rotors. Those are there to be used in lieu of a pulley when the rotors are frozen to the hub. Simply take the appropriate bolts, tightening bottoms the bolt to the hub, and pushes the rotor away from the hub. Another trick of the trade..along with BFH.
I've used the other tip you gave as well but eventually figured out that it's quicker/easier with a rubber mallet.
