Fan belt install
Fan belt install
I just got another fan belt for my s apparently I need to change it out its making that noise while its running. My question is does anyone know how to do it and im sure theres a certain way of doing it. Or better yet we can do a D.I.Y and post it online for others to see at my place??? Any takers let me know so I can knock this out
1-Check that the pointer (A) on the auto-tensioner housing is not beyond the edge of the indicator rib (B) on the tensioner base.
2-Move the auto-tensioner (A) to relieve tension from the alternator belt (B), and remove the alternator-compressor belt.
3-Install the new belt in the reverse order of removal.
Since you are in the neighborhood we could change it out in a few minutes.
Originally Posted by svann,Feb 17 2009, 08:11 PM
The S2000 has electric fans so no fan belt. You probably meant the alternator-compressor belt. The manual shows only 3 steps for removal and replacement. A breaker bar or a big torque wrench is needed to crank the tensioner pulley downwards to release belt tension.
Originally Posted by Funat9,Feb 17 2009, 10:41 PM
easier said than done im more of a visual person than reading im the type if I read im like trying to put a square block in a circle block with a hammer but I rather have someone there with me that knows whats going on so I can make sure I dont mess up and a second eye does help out
Originally Posted by svann,Feb 18 2009, 10:47 AM
I'd be happy to lend a hand. Probably easier if we work in my garage but this only takes a few minutes. I'm off most Fridays or we could take care of it early some evening.
Originally Posted by svann,Feb 19 2009, 02:00 AM
Don't worry about any tools. I have a lunch appointment Friday but the afternoon is clear. I'll text you on Friday. No need to remove the airbox.
Notes for DIY serpentine belt replacement.
CAI owners, good news. Without an airbox the belt replacement takes about 2 minutes. Plenty of room to access the tensioner. The amount of tension on the belt is low so a normal socket wrench can supply enough force to remove and install the belt. There is plenty of room if you want to use a breaker bar to move the tensioner.
Stock airbox owners. Clearance behind the box is tight. A 14mm wrench or socket will just fit to rotate the tensioner. You can still see the belt path but it may take a few minutes to finesse it around the pulleys and tensioner. A flat handle tensioner pulley tool is indicated in the manual. I'm sure it fits easily but few DIY mechanics will have one.
At any rate this is really easy to do. With a CAI you can inspect the belt condition without removal. Stock airbox owners might want to remove the belt for examination or replacement at the service interval.
Funat9, thanks for letting me turn wrenches with you. With proper (f/r stagger) wheels and a few suspension adjustments your car will handle much better.
