Help/ inherited a new S2K/ Southwest VA
Old 02-07-2021 | 06:43 AM
lil'Jack's Avatar
Default Help/ inherited a new S2K/ Southwest VA
Hi, can anyone recommend a good mechanic/shop that knows anything about S2K in Bristol, TN area? Thanks!
Old 02-07-2021 | 08:37 AM
Chuck S's Avatar
Curious why you need a shop. Anything specific wrong? Looking for a maintenance program?
-- Chuck
Old 02-07-2021 | 08:42 AM
lil'Jack's Avatar
Hi, I don't think anything is wrong. It wouldn't start after sitting for 5-6 months. It was purring like a cougar in August and then parked. it probably needs a new battery. I will try that when the snow melts. I just know I will need help because I honestly don't know anything about this car. Just wanted to try to find someone locally that I could talk to. Thank you
Old 02-07-2021 | 08:52 AM
Chuck S's Avatar
I can guarantee the battery is stone dead unless you disconnected it or put it on a trickle charger in August when you parked it. Dead to the point it probably won't revive. No different than any other car. Parasitic discharges from innocent things like the radio memory and keyless entry will suck a battery dry in a matter of weeks. Lots of help here but the battery is the place to start. You'll need the radio code for it to work once you get power.
Some battery chargers won't even try to charge a battery drained completely -- but it won't hurt to try. I'd budget the money for a new battery.
-- Chuck
Old 02-07-2021 | 09:11 AM
lil'Jack's Avatar
what is a radio code and how do i get that?
Old 02-07-2021 | 09:24 AM
Chuck S's Avatar
Hopefully the former owner kept the card with the radio code with the owner's manual. It's an anti-theft code that needs to be used whenever power to the radio is severed -- like when changing a battery or the battery completely dies -- or the radio is stolen. The radio should lightup with C-O-D-E in the display. Someone will recall the link to how to get it if you don't have the code card or it's not written in the owner's manual. Check the secret compartment between the seats, mine was there.
-- Chck
Old 02-07-2021 | 09:38 AM
lil'Jack's Avatar
O.K., I'll check all this out. Thank you-
Old 02-08-2021 | 11:16 AM
lil'Jack's Avatar
Thank you for your help. I found the manual and the radio code card in the pocket behind the driver's seat. I appreciate your help.
classicvin
10-26-2015 02:10 PM
jpark
08-20-2015 08:19 AM
whatset
07-23-2015 10:32 AM
Quick Reply: Help/ inherited a new S2K/ Southwest VA
