FS: F20C Shortblock
Old 08-15-2012 | 07:28 PM
MM3Kwolik's Avatar
Default FS: F20C Shortblock
Hey guys, figured I would offer this to some of the local track guys as a backup/buildable motor before I put it out on the public market. This short block is from a buddy of mine's car that had a momentary oil starvation issue. #2, #3, and #4 main bearings were worn and the crankshaft needs to be micropolished, but is definitely in usable shape. The cylinders have some minor scoring, but that won't matter if you plan on sleeving it to build it up. The motor had just under 60K miles on it when it was torn down. It WAS still running, just had some excessive vibration from the 3 main bearings being worn. Here's a list of everything I can include with it. Price is negotiable, especially if you don't need all of the parts I'm listing. I am asking $600.00 OBO for this full list of parts. Everything is at my Father in Laws in Smyrna, so if you want to see it all, we can arrange a time to do so.
-F20C Bare Block, No Sensors
-Girdle
-Oil Pan
-Oil Baffle Plate
-Crankshaft (needs micropolishing)
-Pistons and Rods (pistons have some minor scoring)
-4 hole oil jet bolt upgrades (with squirters)
-Timing Chain Sprocket
-Timing Chain
-Timing Chain Guides
-Oil Pump Chain
-Oil Pump Chain Tensioner
-Oil Cooler
-Thermostat/Water Pump Housing
-Water Pump
-Water Pump Pulley
-Thermostat Cover
-Timing Cover (with crank position sensor)
-Oil Sending Unit (dummy light)
-Crank Pulley
-Idler Pulley
-Tensioner & Bracket
What you will need to make it a complete Short Block:
-Oil Pump (I have a used one, but might as well get a new one)
-Knock Sensor
-Coolant Hoses
-Gaskets, Seals, O-rings
alanpikku
Arizona Classifieds
06-24-2013 11:55 PM
CaseyGW
04-14-2010 01:40 PM
blueap2
Socal Swap Meet
03-21-2010 02:43 PM
march2000
10-02-2006 05:41 PM
pierceman
13
10-06-2005 06:16 PM
Quick Reply: FS: F20C Shortblock
