Brake Question
Brake Question
Hey guys I am upgrading to steel braided brake lines and the lines I have didn't come with new Banjo bolt washers. Can I reuse the old ones or should I replace with new OEM washers?
What your looking for is a 10mm line wrench and all of the parts stores carry them. Also replacing the banjo washers is required....wouldnt want a leak induced failure because a .20 cent washer wasnt replaced. Just my opinion, Im no pro.....lol. Hope this helps, and I am here anytime just message me.
Brad
Brad
Thanks for the help guys. Autozone had everything I needed, except the superblue dot 4 fluid. So far 2 corners done. Got to the back and the Brake pads aren't correct so I am stalled till I get the right part number. I'll probly move forward with the brake lines while I sort out my pad issues.
I got EBC reds and the little aluminum tab "screech clip" on the inboard pad for the rear left is missing. Part number shows correct. There is a leaflet in the box that tells about a safety notice that there are two designs for this car one with and one without the tab. Really strange. other than the missing tab the pads are identical in shape to oem.
bgoetz
04-07-2015 06:30 AM
chrispayze
10-16-2011 05:01 AM
