Steel braided brake lines installed
i bought a pair of Russell brake lines from bobby at SnR and i just installed them today. they fit nicely, they look good too. i just did a test drive and i need to re-bleed the brakes. but hopefully my rear brake hangup problem has been solved. we will see i guess.
well... i drove the car this morning and sure enough, the rear brake is starting to lock up again. the car stop better tho. thanks chip for the tip
i thought that was the problem, however, i disconnected the ebrake and left the caliper/brake line connected and it still hung up. it was rubbing early this morning but doesnt seem as bad when i went to lunch. guna bleed the brake tonight and see if that solves the rest of my problems
