Tampa Gulf coast and surrounding areas...there be pirates here!!
Need a little help with my door lock
Old 03-23-2009, 02:42 PM
JohnsS2000's Avatar
With the lock I mean.
Old 03-24-2009, 04:40 AM
PENROD's Avatar
No, there was no issue before, but 'before' is about 4 years ago.
John, I'm not sure where you are located in Tampa, but I'd be willing to come see you some evening you are available so we could look at this thing and see what's going on. I'll PM my phone number so you can call if you're available.
I'm a little leery about going to Honda. I'm afraid they're going to tell me I need some million dollar lock assembly, and it is hard to believe it's not something simple.
the history:
tab broke a while back, not sure why or how.
I left it untouched fro the longest time and everything worked fine (fob, outside handle, locking with key, etc, just not the locking tab from inside).
I took the door panel off to replace the door speakers (still didn't mess with the handle, rod or anything else) and when I put it back on, the fob, key from outside wouldn't work.
I bought the replacement inside handle assembly and when I put it back on, the fob then worked and I could lock it with the key from the outside, but the locking tab still wouldn't engage without putting pressure on the 'open' rod.
I'm perplexed, but I am fully convinced I twisted something or moved something out of it's intended place. Again last night I took everything apart and tried to look at what I could see, but to no avail.
I also couldn't see where or how I could turn either of the rods as you suggested.
Thank you for sticking with me on this!
Old 03-24-2009, 04:50 AM
PrimoGen's Avatar
I wish I had any good advice on this one. if the issue gets solved please post a detailed description if possible
good luck
Old 04-12-2009, 05:52 AM
Nickamsweet's Avatar
I have a similar problem, try to lock the door on the driver side and it just won't lock at all... but can manualy operate the passenger lock and it's fine...
Going to go have a look just now, take it apart and ATTEMPT to fix it lol
Old 04-15-2009, 01:01 PM
2big4aS2000's Avatar
if you have not gotten this fixed, I could pull the door apart and take a look for you, aleast you will know what really is wrong with it.
Old 04-16-2009, 11:54 AM
PENROD's Avatar
Nick,
What did you find?
2big, where are you located/ sounds like you have experience with this?
Old 04-16-2009, 12:24 PM
tampa!
rolso72
09-11-2016 02:02 PM
bruce0293
05-24-2013 04:37 AM
richjsy
05-14-2013 02:43 AM
PENROD
03-18-2009 01:47 PM
Shark
09-26-2001 03:44 PM
Quick Reply: Need a little help with my door lock
