Is it my wheel bearing or tires (rs3's)
Long story short. Humming sound from the rear of the car after 60. It goes away the slower I go. I did axle cup swap about 2 months ago with S2Kwalt and everything went perfect no noise or vibrations after. Install new rs3's and sounds starts about a 2 months later. Could it be just a noisy tire or a bearing
Here's the video
https://www.youtube.com/watch?v=DBWa...e_gdata_player
Here's the video
Sounds like a bearing test it by lifting the car up and wiggling in and out from top to bottom if the tire moves is the bearing
Sent from my Galaxy S4 using Tapatalk 4 Beta
I had a rear bearing problem and replaced it a few years ago. This does not sound like a bearing or at least the way mine sounded.
I had many people diagnose mine and many thought it was a tire, mine was more of a clicking sound and the hotter it got the noisier it was, speed was also a factor it made more noise at low speeds vs highway speeds. This may have been a factor of simply being able to hear it more at low speed due to road noise etc.
A quick way to check is to jack up the rear and face the tire, grab it at 3 & 9 o'clock and try and rock it back and forth (in & out) if the wheel has any play you have a bearing problem. The movement may be very small but at speed it is magnified obviously.
If this is the problem have it fixed immediately as this is obviously a dangerous situation. I had mine done at the dealer, (not everyone is equipped to press the bearing into the hub), also have them check the hub to make sure it isnt damaged. I chose to replace mine while we had it apart and the total bill was just under $400 (new bearing, new hub and labor)
Good Luck!
Good Luck!
