Local Tampa mechanic needed
Car won't hold an idle, when I turn the AC on. Don't want to take it to the dealer. But I will :-)
Can I get any help here on someone who knows about our cars?
thanks in advance.
I'm in the Tarpon Springs area
thanks in advance.
If you bring up the RPM then turn the a/c on, does it work? Any strange noises with the a/c on? Any other issues with the engine (does it run well)?
Likely either the idle control stuff isn't working (Idle air control valve or associated electronics), or the a/c is failing and putting too high a load on the engine, causing the idle to fall.
S 2 S L O W
08-11-2017 06:19 PM
