compression test on the S today
Did a compression test on the S today and the numbers are crazy good
My car is a 2000 S2000 with 41,747 miles. Starting From front to firewall in order #1 245, #2 246, #3 241, #4 245
Mobil1 10/30 oil, about 1,800 miles on oil since changed.
I bought the car back in Oct and never did a compression test. I figured I would get to it once I got my tester back from the friend I loaned it to monthssss ago
I want to do a valve adjustment and then do the leak down test next. The car runs and feels strong I'm just going through the car a little more as I get time.
Wow, great numbers for higher mile cars I think the 250 psi is the top of the new engine standard. I will probably redo the test once the valves are adjusted and she has a fresh oil change.
Oil change shouldn't make a differnce on compression numbers, but if you have a valve slightly out of spec it may help, but those numbers are absolutely nothing to be concerned about. Motor looks to be super healthy.
