Cabin Air Filters
Cabin Air Filters
Hello Tampa Group!
FYI
As a new owner of a used 2002 AP1 with 75,000 miles and not knowing the maintenance history, I have been in the process of changing out all the fluids and filters.
My son mentioned to me that the cabin air had a "musty" smell. I also noticed the AC seemed to have low air flow. After researching this item on the main S2K website I discovered that many owners forget to replace the filter. I removed mine and found a totally clogged filter. Replacing the filter seemed to help both problems.
FYI
By the way, here's what my old filter looked like.
Also learned a little trick using a 5mm socket to remove plastic pins holding the rubber
hood seal. Push the socket from the bottom and the pin pops out.
HONDA pt. #79831-S2A-003; About $25, well worth it!
Pete
Pete
I order my cabin filters & engine air filters here: H & A Accessories
Great prices, I usually order 2 of each to save on shipping.
part of my tune up special you get this filter changed along with adjust the valves, new plugs, clean intake and fuel system, throttle body and the path air and fuel travel with BG system cleaning products.
