Anyone know of a Zex dealer locally?
Those plugs are not that great. Is there a reason you want to use those? If you want i'm pretty sure Automotive Engineering has them in stock. they are in Pinellas on Ulmerton and US19
Originally Posted by SweetS2K,Aug 29 2008, 02:30 PM
I need a 2 step colder plug. What is the best option?
I just had a KW SC installed and am running NGK IFR8H11 for my plugs (Elroy reccomended them for my set up). Not sure if this helps. But advice is free...it's repair that are expensive.
thank you, yes I am currently on a wet 75 shot. No problems, but have decided its time to change the plugs again. I have had the Zex plugs, but after searching the forums, it appears NGK is the better plug. So if I only need a one step colder plug, should I go with the plug that has the resistor? I see there is a iridium NGK with a resistor and there is a copper NGK w/o a resistor. Both are one step colder plug...I appreciate the advice.
I've always run a copper plug when spraying. I would suggest posting in the FI forum. See what those guys say. It's also a good idea to change your plugs often when spraying
