URGE designs Mag Wheels
Full story and details on our site.
Magnesium Wheels optimized for the S2000.
5 great combos to fit common S2000 needs
- Lightest weight track wide (9.5 to 10.5") wheels available (13.8 to 15.3 lbs)
- Even at 18", lighter than 17" options by 2-3+ lbs per wheel, plus 18" tires typical weigh a little less than 17" (less sidewall) for 3-4+ lbs per wheel/tire savings
- Lighter than typical 18's by 5+ lbs per wheel.
- Widest wheels for OEM S2000 fenders and +1mm over fenders (every 1" of wheel width is worth ~1 sec per 2 min track time)
- 18" wheels support S2000 25" diameter better than 17" (worth an additional ~1 sec per 2 min or track time)
- Maximum BBK clearances
- Magnesium has incomparably high dampening factor with noticeably less NHV than Aluminum wheels
- Made by an OEM wheel supplier
- 9.5" high offset (13.8 lbs) to fit front OEM fenders ($1350 per wheel)
- 10.5" high offset (15.3 lbs) to fit front OEM fenders ($1400 per wheel)
- 10.5" higher offset (14.6 lbs) to fit rear OEM fenders ($1400 per wheel)
- 9.5" front and rear, OEM fender fitment, front to rear tire rotation
- 9.5" front, 10.5" higher offset rear, OEM fender fitments
- 10.5" high offset front (needs +1" front fender/pull), 10.5" higher offset rear for simple, non staggered fitment
- 10.5" higher offset front and rear, with 20mm front spacer and +1" front fender/pull, front to rear tire rotation
- 10.5" high offset front and rear, +1" stance and fender/pull front and rear, front to rear tire rotation
MuttGrunt (07-07-2024)
shrykhar (06-03-2024)
Grassroots motor sports have tested 18's to be 1 second faster per 2 mins of lap time due improved tire control.
There are not available 17" Mag wheel forging at the wider diameters.
Additionally, 18" wheels have proven to be faster than 17", even on lower HP cars.
Setsuna (07-21-2024)
