SakeBomb Garage Wilwood Track Day Brake System Introductory Sale!
#21
The AP Kit is designed to be an ultra-high performance racing setup, typically for competition track use. The rotors actually weigh slightly MORE than our two piece SBG rotors, as they have a higher cooling vane count. They are fully floating to handle the extreme differences in temperature between the rotor and hat in heavy track use conditions, which prevent coning of the disc in relation to the hat and allow the rotor to expand radially. This only comes into play when the discs are loaded up with extreme heat, which is why we recommend them for heavy track enthusiasts or competition track use. For HPDE's the standard rotors are more than sufficient! The AP Calipers are also slightly lighter compared to the Wilwoods, but the real benefits are that they have anti-knockback springs in the pistons, protective cross over tubes, higher temp seals, and they're somewhat stiffer. That said the Wilwood kit was meant to be a budget-friendly little brother to the AP Competition kit... they're both quite good but if you're looking to eek out the fastest lap times and are very hard on your brakes, consider the AP setup. If not, our Wilwood Track-Day kit is a great bang for the buck, and does have the option for AP rotors should you want a hybrid kit.
__________________
SAKEBOMB GARAGE > Click here to contact Us
Check some of our most popular products for the S2000:
- Ohlins DFV Billet Lower Mount
- Rear BBK RX-8 Caliper Conversion
- Front BBK AP Competition
- Setrab Oil Cooler Kit
#23
The pre-order is over but we are offering free shipping on all brake products through the end of October. Use coupon code BRAKETOBERFEST2016 at checkout
__________________
#24
Originally Posted by DavidNJ' timestamp='1475385042' post='24074703
From the picture iooks like the bracket is adapting 3.5" mount calipers rather than radial mount calipers.Is that correct?
#25
Huge inventory blowout sale, Lowest price ever and won't be seen again. $999 for the first 4 kits sold.
New Year Inventory Blow Out!
__________________
#27
We haven't tested this wheel personally but it should be very close. With a 3mm spacer you should be good.
__________________
The following 2 users liked this post by Tougefactory:
devildust (01-24-2017),
SakeBomb Garage (01-30-2017)
#30
__________________
