Rockstar Garage Suspension Specials
Rockstar Garage recently received our latest suspension shipment and we want to pass the savings to the s2ki community. If you don't see the coilover system of your choice please don't hesitate to contact us.
Race Proven technology only at Rockstar Garage!
Ohlins DFV Coilover
The Features of DFV Technology
So what is DFV? It is Dual Flow Valve technology – and it sets us apart from our competitors. Only Öhlins has DFV technology on its road and track products
With DFV, the dual flow valve gives the same characteristics on rebound as it does on compression, thanks the damper fluid having a consistent path of flow in both directions. This means that the wheel and tire can quickly and effectively resume their important position back on the ground, providing grip and traction. The new Öhlins R&T range uses DFV technology on every single fitment, making it the perfect upgrade for the enthusiast that needs comfort and agility in the one unit.
Contact us for special pricing
Skunk2 Pro-C coilovers (New and improved Version)
Skunk2 is proud to its Pro-C Coilover system for Honda’s S2000. Skunk2 Pro-C Coilovers offer the latest advanced shock technology, featuring an adjustable, race-inspired mono-tube design for dramatically improved handling and cornering performance. Skunk2’s mono-tube design, coupled with oversized shafts and pistons, help make each Pro C dampener both responsive and durable. Pro-C Coilovers also feature shortened shock bodies and shafts to maintain proper suspension travel on lowered vehicles. All Pro-C shock bodies are fully adjustable to allow for additional height adjustments independent of spring preload to help dial in all aspects of the vehicle’s balance and feel.
MSRP 1500 -> 1000 shipped
FEATURES:
Large Diameter, Mono-Tube Design
12-Way Adjustability
10kg (554lb) Springs
Shortened Shock Body And Stroke
Forged Billet Upper Mounts
High-Quality Shock Oil
Triple Upper And Lower Seals
Buddy Club Racing Spec Evo Damper
"Racing Spec Damper" is the perfect complete suspension kit with resemblance of P-1 racing damper's excellent designs while it is de-tuned for street - circuit use. However, the car specific pillow-ball upper mount design, proper spring rate, 15 level damper adjustment, and height adjustment capabilities accommodates driver's requests.
Racing Spec Damper Kit is a high performance sports suspension kit designed by engineers using a vast quantity of data that Buddy Club has accumulated in the past 15 years using its high performance aluminum damper (ie. spec 30.1 Racing Damper) on various racing cars and tuned cars, focused more on the proper damper size, spring rate, dampening, stroke length for customer's use in winding roads and race tracks.
Rockstar Garage exclusive 2000 shipped.
We also offer the n+ replacement which offers a new and improved design. Contact us for special introductory pricing.
Simply PM us for any questions or give us a call at 909-766-0774 for the fastest response. We look forward to serving the s2000 community for many years to come. Let us help you turn your stock car into a race car!
Ohlins DFV Coilover
FEATURES:
SakeBomb Garage
05-23-2019 05:26 PM
SakeBomb Garage
06-21-2017 08:59 AM
