Sponsor S2000 Suspension, Brake and Handling Deals Sponsor deals on S2000 suspension and S2000 handling products
Karcepts Sway Bars
Old 07-18-2021 | 06:23 PM
Urge's Avatar
Sponsor
Default Karcepts Sway Bars
The most adjustable and balanced S2000 sway bars
The S2000 has oversteer that can flip you180 degrees when pushing the limits.
Additionally, the inside rear tire typically lifts making the OEM diff open reducing rear applied power.
Optimal S2000 front sway bar rates are about 2-3X stiffer than OEM improving front end responsiveness and enabling wider wheels carrying more speed and brake harder with out increasing oversteer
Optimal S2000 rear sway bar rates are 1/2 to 1/3 softer in the rear reducing oversteer and inside rear tire lift
Combined, the above set-up creates the best balance for the S2000
The Karcepts Sway bar provide this range of adjustment providing as much or more chassis tuning than adjustable coilovers
See our sway bar story on our site.
Both the front and rear sways include
  • Ultralight billet aluminum arms
  • Ultrastong FEA optimized design
  • Highly adjustable w/ 11 front adjustments and 13 rear
  • Adjustments can be made with out needing a lift
  • Includes lightweight, zero deflection, sway bar mounts
  • Includes length adjustable, PTFE end links
  • Steel splined center sections w/ 1.25" diameter front and 0.875" rear
Front Sway Bar Set
Rear Sway Bar Set
__________________
Old 08-13-2023 | 06:19 AM
Urge's Avatar
Sponsor
88 front sway and 66 rear sway bars sold!!
Email urgedesigns(at)gmail.com for questions and quotes
__________________
ITR
09-20-2011 08:38 AM
scirocco25
07-21-2008 05:23 PM
krazik
04-16-2003 01:25 PM
Quick Reply: Karcepts Sway Bars
