Sponsor S2000 Suspension, Brake and Handling Deals Sponsor deals on S2000 suspension and S2000 handling products
FPSpec Ohlins Low-Profile Mounting fork Package Deal!
Old 06-13-2017 | 03:09 PM
SakeBomb Garage's Avatar
Sponsor
Thumbs up FPSpec Ohlins Low-Profile Mounting fork Package Deal!
Do you have Öhlins and need some extra equipment to drop some lap times?
We have you covered! This package deal includes:
Our newly released FP Spec Low-Profile Mounting forks
FP Spec Ohlins Remote adjusters
FP Spec High Torque
One Time special introductory offer for:
$425
Purchase on our site now!
Lower Fork + Remote Adjusters + DFV Wrenches - SakeBomb Garage LLC
$425
FPSPEC OHLINS DFV LOW-PROFILE MOUNTING FORK (S2000) (Reg price: $295)
We sell a lot of Öhlins DFV and although we hear almost nothing but great things about them the single recurring comment is that the rear damper doesn't allow the car to be lowered to the ideal height. Regardless of if you are running high spring rates for the track, enough preload to achieve ultimate performance on the standard springs or even trying to live life hellaflush, the standard lower mount design leaves a lot to be desired. We recommend a high amount of rear pre-load with near standard spring rates (8-10KG) when setting up the conventional DFV suspension due to the limited available stroke. 10-30mm of spring pre-load is needed to obtain an optimal balance of compression and rebound and stay off the bump stops for best ride quality. This does come at a cost however, as it will limit the amount of ride height adjustment the can be achieved. As pre-load increases, the damper length must decrease to keep the car at the same ride height. Unfortunately the standard lower mount does not allow the car to be lowered as much as many people would like, especially with the correct amount of preload. This is where our mounts come in!
FPSPËC ÖHLINS DFV REMOTE DAMPER ADJUSTERS (Reg Price: $145)
The FPSpëc remote damper adjuster for Ohlins DFV's allow for full control of your dampers, with a simple turn of a our remote panel mount knob, anodized to match Ohlins suspension. With care to design and detail, we custom engineered every component in this kit to reflect the quality of Ohlins suspension. Simply slide the lower billet hard-anodized aluminum cap over your standard gold Ohlins adjuster knobs and fasten in place with the set screw (ball end allen key included). Insert the remote adjuster cable, and run to the desired panel mount location. Add the remote knob and you're ready to roll. All parts designed and manufacturered by SakeBomb Garage. Our high-flexibility remote adjuster cable with low friction PTFE sleeve allows for fine tactile control of the damper knob (you'll still feel every click as if you were adjusting the damper directly). Custom sized for your application (and available in custom lengths for bespoke applications).
FPSPEC HIGH TORQUE DFV ADJUSTMENT WRENCHES (Reg Price: $55)
We created a fully redesigned wrench that allows you to adjust every aspect of your Öhlins with a single wrench. After driving and a good few track days adjusting your suspension with the OE wrenches is nearly impossible. Adjusting cars became a chore and we couldn't handle that, so we needed to fix this. The wrenches allow adjusting our car to be a breeze and get you able to fine tune everything you wanted to do on the fly
Old 07-07-2017 | 10:23 PM
Sponsor
Old 10-19-2017 | 05:11 PM
Sponsor
Special Track package, get all setup with this FPSpec pack!
Old 10-27-2017 | 01:37 PM
Sponsor
THMotorsports
03-01-2017 02:48 PM
THMotorsports
11-05-2016 11:15 PM
THMotorsports
65
07-09-2016 12:44 PM
Deepblue
08-21-2012 06:27 AM
Deepblue
08-05-2012 02:35 PM
Quick Reply: FPSpec Ohlins Low-Profile Mounting fork Package Deal!
