Sponsor S2000 Suspension, Brake and Handling Deals Sponsor deals on S2000 suspension and S2000 handling products
Centric - Reverse Mount Front Rotor Directional Vane Blank Set - NEW!
Old 07-25-2013, 04:46 PM
Former Sponsor
GT Motoring's Avatar
Default Centric - Reverse Mount Front Rotor Directional Vane Blank Set - NEW!
New for 2013! As always we try our best to bring the latest and greatest parts to the S2000 community. Centric now offers their reverse mount rotors in blanks for those doing heave track duty! Directional vented rotors feature vanes that are directionally oriented for both the left and the right rotor to allow air flow to be pump from the inside out. The center reverse mounted hub of the brake rotor places the ventilation on the wheel side of the rotor for increased air flow. The reverse mount design allows the factory heat shield to be retained in order to protect the suspension and steering joints from heat. The cooler running rotor will allow more consistent brake performance, increased durability, and a longer use life. In addition to increased durability from the rotor - suspension joints, steering joints, and wheel bearings will benefit from cooler running rotors. These rotors are factory sized and not 2 piece, so no additional class points required.
Features:
- Improved cooling efficiency - compared to factory & aftermarket straight vanes, directional vane rotors improves durability of brake components, suspension & steering joints. 12% cooler temperatures on track ( confirmed on track by SOS S2000 testing )
- Lighter weight design - front rotor ~1 lb lighter than factory
- Epoxy coating - coating on non swept areas (hub & vanes) inhibit corrosion to keep rotors looking great.
- Double disc ground - taper free finish ensures parallel surface and better brake pad - rotor break in.
- Mill balanced - additional machining operation eliminates rotor vibration.
LINK to site for to purchase:
http://www.gtmotoring.com/product_in...oducts_id=1732
FREE SHIPPING within the mainland USA
GT Motoring is offline
Old 07-25-2013, 04:59 PM
Metcalfe's Avatar
Slotted option available? Price please.
Metcalfe is offline
Old 07-29-2013, 05:12 PM
Former Sponsor
PM'd details
Old 08-08-2013, 08:15 AM
Former Sponsor
2 sets left in stock!
Old 08-16-2013, 05:17 PM
furian777's Avatar
Still available? Is there a corresponding rear set? Also curious about the slotted info as the guy above mentioned?
furian777 is offline
Old 08-18-2013, 07:49 AM
Former Sponsor
Still in stock. The rears are solid disks, so no way to do the reverse mount or vanes in it.
I'll PM you details for slotted if you are looking at that direction.
Old 10-01-2013, 01:33 PM
Former Sponsor
More rotors available now.
Old 10-01-2013, 03:29 PM
JUSTINTHECOASTIE's Avatar
Pm price shipped to 33710 please
JUSTINTHECOASTIE is offline
Old 10-21-2013, 08:18 PM
Requiem's Avatar
slotted option shipped to 34609 please.
Requiem is offline
Old 10-25-2013, 10:19 AM
Former Sponsor
PM'd details
Quick Reply: Centric - Reverse Mount Front Rotor Directional Vane Blank Set - NEW!
