Sponsor S2000 Suspension, Brake and Handling Deals Sponsor deals on S2000 suspension and S2000 handling products
ÖMG! - Öhlins @ SakeBomb Garage
Old 12-24-2016 | 08:13 AM
  #31
SakeBomb Garage's Avatar
Sponsor
Old 12-26-2016 | 03:19 AM
  #32
md6380's Avatar
If these or ordered through Sake Bomb, will you help with settings to get desired pre-load and heights just as detailed as Ohlins? For example, if you're recommending for a 8 kg/mm spring and 1" of lowering, X mm or pre-load is needed, which will raise the car Y mm's, so total shock length should be W mm's and the distance between the height adjuster and the shock pre-load adjuster should be Z mm's? Similar to how the Ohlins manual is detailed.
Old 12-26-2016 | 09:26 AM
  #33
Sponsor
Yes the setup guide is even more detailed than ohlins, we take into account all of modifications and usages of your car and determine our reccomended settings. We will then provide you all of the dimensions you will need to achieve your target ride height (either suggested or requested). Ohlins only provides instructions for a single setup assuming the rest of the car is stock (no weight reduction, RCAs etc).
Old 12-31-2016 | 08:42 PM
  #34
Sponsor
Old 01-04-2017 | 10:18 PM
  #35
Sponsor
We have one more open box set available. Check it out here: https://www.s2ki.com/forums/member-s...ecial-1167498/
Old 01-06-2017 | 10:42 PM
  #36
Sponsor
Old 01-14-2017 | 07:58 PM
  #37
Sponsor
Old 01-19-2017 | 12:02 AM
  #38
Sponsor
Check out our newly release FPSpëc Öhlins DFV suspension. More than just a revalved standard kit, this is a fully re-engineered long stroke suspension with significantly more rear travel, floating top hats and our popular billet low profile rear mount. Most importantly each and every kit is specifically tailored to your individual needs with any swift springs included in the price along with damping curves to match! Every component of the FPSpëc suspension was overhauled to provide the ultimate road & track damper.
Check out the main thread here:
https://www.s2ki.com/forums/s2000-br.../#post24137706
Old 01-22-2017 | 11:33 AM
  #39
Sponsor
Old 01-27-2017 | 07:14 AM
  #40
Sponsor
Quick Reply: ÖMG! - Öhlins @ SakeBomb Garage
