Sponsor S2000 Exterior and S2000 Interior Deals Sponsor deals on S2000 Body and S2000 Interior accessories
APR Aero - GT-250 wings, Splitters, Canards and more
Old 02-07-2013, 08:24 AM
Former Sponsor
GT Motoring's Avatar
Default APR Aero - GT-250 wings, Splitters, Canards and more
GT Motoring now proudly offers APR Performance products.
Since 1999, APR Performance has been producing and manufacturing high quality performance products for the aftermarket automobile industry. Every product is track tested to assure they are able to withstand the extreme environment of the track.
With capabilities to produce products in both Carbon Fiber and Aluminum manufacturing processes, APR’s products are durable and lightweight. These composite technologies allow APR to maintain its high levels of quality and durability.
__________________________________________________ _____
GT-250 2D Wing
Recently released, all GT Series wings feature an all-new, low-drag, aerodynamic 2D designed airfoil shape. The "2D" design allows the wing to maintain a consistent level of downforce across its entire span. Computational Fluid Dynamics (CFD) Analyses were performed on these wings to support validation of their aerodynamic design.
Each GT Series airfoil is composed of lightweight and durable carbon fiber reinforced polymer (CFRP) composite materials. These airfoils contain pre-pregnated woven carbon fiber sheets for superior strength and low weight. All CFRP airfoils are made using pre-pregnated composite manufacturing processes (i.e. high-temperature autoclave and vacuum bagging) in high-quality aluminum billet molds.
Each GT Series airfoil is composed of lightweight and durable carbon fiber composite. Supporting the carbon fiber airfoils are 10mm "aircraft grade" 6061 billet aluminum pedestals that come in a flat black powder coat finish.
*S2000 Specific Application available in 61" and 67" widths
*Gurney Flap Available
GTC-300 3d Wing
With a span of 67 or 61 inches and a height of 13 inches, the GTC-300 is an adjustable wing that means serious business. The GTC-300 3D airfoil shape allows for optimal airflow that reduces drag yet supplies an effective amount of downforce. Computational Fluid Dynamics (CFD) analysis was performed on this wing to support validation of its aerodynamic design.
Each GTC Series airfoil is composed of lightweight and durable carbon fiber reinforced polymer (CFRP) composite materials. These airfoils contain pre-pregnated woven carbon fiber sheets for superior strength and low weight. All CFRP airfoils are made using pre-pregnated composite manufacturing processes (i.e. high-temperature autoclave and vacuum bagging) in high-quality aluminum billet molds.
Supporting the airfoils are 10mm "aircraft grade" 6061 billet aluminum pedestals that come in a flat black powder coat finish.
*S2000 Specific application in a 61 or 67 inch span
GTC-200 3d Wing
Spanning 59.5 inches and a height of 10 inches, the GTC-200 adjustable wing offers the perfect amount of downforce for midsize and compact cars.
APR Wind Splitter
To combat the effects of front end lift, APR Front Wind Splitters are utilized to give extra traction and control in the front of a car. By creating a high pressure area on top of the wind splitter, high pressure air flow is restricted to flow underneath a car. With low pressure below the car, the effect of lift is reduced and a driver can gain from the extra traction and control.
Features:
*Carbon Fiber Reinforcement
--All APR Front Wind Splitters are reinforced with sheets of carbon fiber.
*Fully Functional Undertray
--Our Front Wind Splitters are not just add on cosmetic pieces. Every APR Front Wind Splitter completely covers the entire area below a cars front bumper. This allows for smoother air flow below the front bumper, creating more efficient downforce.
*Support Rods Included
--Supporting every APR Front Wind Splitters are stainless steel Support Rods.
*Available Configurations
--AP1 w/out factory lip
--AP1 with factory lip
--AP2 with factory lip
--AP2 without factory lip
--AP1&2 with APR Front bumper w/ Air Dam Incorporated
Front Canards
APR Front Bumper Canards are the perfect answer to aerodynamically tune the handling for the front of a car. Made of lightweight and durable carbon graphite composites, APR Front Bumper Canards help increase front downforce at high speeds. The added downforce stabilizes the cars chassis during hard cornering and increases traction for faster lap times.
Features:
*Carbon Fiber Construction
--These APR Front Bumper Canards are made using pre-pregnated carbon fiber manufacturing processes, for high strength and low weight.
*UV Resistant Coating
--Each APR Front Bumper Canard is made with UV-stable epoxy and clear-coat materials for resistance against fading.
*Mounting Hardware Included
--Screws, nuts and bolts are all included to allow you to install the APR Front Bumper Canards to your car.
**Only Fits AP2 Front Bumper
**Available in Regular and Lightweight Versions
Front Air Dam / APR Front Bumper with Incorporated Air Dam
Underbody components such as front air dams, undertrays, and rear diffusers are essential for maximizing aerodynamic performance. The APR Performance Front Air Dam integrates with the factory front bumper to:
- Reduce lift.
- Increase front-end stability.
- Improve high-speed cornering grip
This Front Air Dam also utilizes a built-in aerodynamic splitter design that creates a high-pressure region of air atop the protruding surface, further reducing lift and increasing net downforce.
APR Air Dam - Carbon Fiber Only
APR Front Bumper with Air Dam Incorporated - Fiberglass Only
APR Rear Diffuser for S2000
Diffusers work in conjunction with other aerodynamic components of a car to help produce downforce. Because a car displaces air as it moves forward, the air molecules in the rear of the car get disrupted causing a vacuum of low pressure air.
To help channel the high speed air flow coming from underneath the car, diffusers redirects the high speed air flow to transition smoothly transition into the low pressure vacuum in the rear. This encourages a smoother flowing air flow underneath the car and allows better performance from other aerodynamic components such as aerodynamic wings.
Versions Available:
*AP2 in Carbon Fiber
*AP2 in FRP
*AP1 in Carbon Fiber
*AP2 in FRP
Formula GT3 Mirrors
When it comes to reducing aerodynamic drag to a car, the APR Formula GT3 Mirrors are an excellent choice. The APR Formula GT3 Carbon Fiber Mirrors are designed to give race inspired looks with the functionality of reducing drag and eliminating blind spots with wide angle mirror lenses.
Features:
All APR Formula GT3 Mirror housings are reinforced with layers of carbon fiber sheets for weight reduction and added strength.
Wide Range of Adjustment
Every Formula GT3 Mirror include a left to right pivot arm at the mirror housing with an adjustable ball stub rod to allow a wide range of adjustment.
Aerodynamic Shape to Reduce Drag
These carbon fiber mirrors are compact and aerodynamically shaped for a low drag coefficient.
Billet Aluminum Bases for Easy Installation
Lightweight & durable billet aluminum mounting bases are specifically designed to factory specifications for easy installation and clean fit and finish.
5.5" Wide Angle Convex Mirror Lens
Convex lenses are used on both driver and passenger sides mirrors to eliminate blind spots. Blue anti-glare mirror lenses are included to reduce reflections from headlight glare during nighttime driving. Please note: Blue anti-glare mirror lenses found only on 5.5" wide APR Formula GT3 Mirror housings.
All screws, bolts and mounting gaskets are all included to allow you to install the APR Formula GT3 Mirrors to your car.
Radiator Cooling Plates and Spark Plug Covers
The flow of air is not only limited to the outside of a car. To maximize cooling capabilities, a radiator needs a direct flow of air to allow an engine to maintain consistent temperatures on the race track. Because of structural gaps above the radiator, the flow of air could escape making the radiator not as efficient as it could be.
To help improve the flow of air into the radiator, APR Carbon Fiber Radiator Cooling Plates can be utilized to channel the flow of air directly to the radiator. This will improve the efficiency of the radiator while adding a high-tech, race inspired look to your engine bay.
Features:
Pre-preg. Carbon Fiber Manufacturing Process
The APR Radiator Cooling Plates are constructed by high temperature and pre-preg. carbon fiber production process, making them durable and able to withstand elevated engine bay temperatures.
Designed for Easy Installation
The APR Radiator Cooling Plates are designed to factory specifications for easy installation and clean fit and finish.
Fade Resistant Epoxy Coating
To ensure durability, the APR Radiator Cooling Plate uses fade resistant epoxy coating to reduce the effects of high engine bay temperatures.
*Cooling plate available with cutout for spoon intake
For Questions, More Information, or Pricing and Availability, please PM or email austin@gtmotoring.com
GT Motoring proudly accepts payment by paypal (paypal@gtmotoring.com) as well as VISA/Mastercard over the phone (847.466.7463).
Normal Business hours:
Mon-Fri 10am-6pm CST
Sat/Sun - Closed
GT Motoring is offline
Old 02-07-2013, 09:00 AM
Cougar1973's Avatar
Price for GTC-200 3d wing with and with out gurney flap shipped to 85749 please. thanks
Cougar1973 is offline
Old 02-07-2013, 09:33 AM
Former Sponsor
PM sent
Old 02-07-2013, 11:02 AM
Former Sponsor
Originally Posted by DaGou
I want one of everything! Send pricing...
How does the open are of the front bumper compare to the open area of a AP2 front bumper? I would only change if I could be assured that I would have more area for cooling air to enter, not less.
On the wings it says: "The results of this analysis are available here." But there is no here. Need the info to pick a wing.
I want a wing, maybe a bumper or splitter, a set of mirrors, and a rear diffuser(I will take FRP here).
PM sent. thanks
Old 02-10-2013, 02:40 PM
rios2k41's Avatar
ap2 rear diffuser in FRP shipped to 24060?
rios2k41 is offline
Old 02-11-2013, 06:38 AM
Former Sponsor
PM sent
Old 02-21-2013, 05:58 AM
obriener2054's Avatar
are the s2000 specific mounts for the APR wing available on there own to replace broken ones???
obriener2054 is offline
Old 02-21-2013, 07:16 AM
s132nr's Avatar
Best price for ap2 Frp rear diffuser shipped to 33545
s132nr is offline
Old 02-21-2013, 09:51 PM
hipopkboy's Avatar
Need a quote on Formula GT3 Carbon mirror and GTC 200 wing to 94579.
Hipopkboy
hipopkboy is offline
Old 02-22-2013, 08:46 AM
Former Sponsor
Hipopkboy
PM sent
Quick Reply: APR Aero - GT-250 wings, Splitters, Canards and more
