URGE designs Jerk Cams
Sponsor
Please visit our site for full details including the jerk comparison vs OEM.
URGE designs Jerk Camshafts
RR Spec $1400
Here is our built motor with our halo stroker kit, ITB and stoker header on 12.5 CR and pump gas with same cams. Over 300 WHP on mustang dyno or >380 at the crank.
We have 2 other specs in progress.
- We branded "Jerk Camshafts" as we optimize the lob profiles to reduce jerk, even with >1 mm lift vs OEM, we have lower jerk (change of acceleration or smoothness)
- Billet S7 tool steel, the stiffest camshaft material readily available minimizing deflection between #1 and #4
- Ground using CNC machine vs cam cards for most accurate grinding
RR Spec $1400
- IN ~13.5mm lift or ~1.5mm more than AP1, ~5 degrees more duration that OEM
- EX ~11.6 lift or ~0.7mm more than AP2, ~similar duration to keep torque
- Stroker spec for 99mm strokes
- 10K spec for 10K RPM
- High strength CrSiV with large wire diameter providing 341 lbs/in spring rate
- Reduced spring coils supporting higher valve lift up to 0.650” or 16.5mm
- Single spring design reducing spring weight ~10% vs OEM raising redline support (dual valve springs are heavier than OEM)
- Spring surface and heat treatment maximizes lifetime with no pressure degradation
- Strongest Titanium alloy (Ti-17) retainers @ ~30% higher strength and 7 points harder (HRC) vs typical Ti 6Al4V retainers
- Reusing OEM bases and AP1 keepers to keep cost down (30% lower cost than typical premium high RPM, high lift and long life springs)
RR Spec $1400
RR Spec $1400
Sponsor
- There are several ways to measure a camshaft, at the lobe, at the valve, with or without lash and several different common lift points. If a customer is comparing lift or duration that was measured differently, then info will not provide good info for them.
- We have measured many camshafts and more than half of all advertised specs are inaccurate
- Lift and duration really dont matter individually, it is how the cam performance on a particular situation (specific build and motor) and we publish those results
- Finally, most think bigger is better and it is to a certain point. We have found a limit for different motors where bigger is worse across the board (not just in one area). So sharing our specific specs can be copied easily.
Setsuna (09-16-2024)
Sponsor
46 sets sold, with dozens of stock bottom F20/22C over 250 whp
Please email us at urgedesigns(at)gmail.com for questions or quotes
We also have 3 sets of regrinds from previous profiles and test cams for $500 off while supplies last
We also offer Toda HD chain, HD TCT and Cam Gears
- Upgrading the TCT is a must as OEM TCT as Honda has provided notice for OEM TCT. Toda HD TCT is priced better than comparable options and not core swap is required
- Replacing the timing chain is recommended if you have over 100K miles due to likely chain stretch. Toda HD chain is more durable than OEM at similar price.
- Cam Gears are NOT needed for our cams, but they can help tune URGE designs Cams to squeeze more power out on built/custom bottom ends.
- On OEM bottom ends, Cam gears can provide more mid range by safely advancing cams with HD TCT/chain and proper P2V clearance
