Fumoto Oil Drain Valve - Easiest oil change ever!
#41
Sponsor
Yessir, it is in stock. Just go to http://www.js2k.com/ to order. On the product page, it should show an accurate number of units in stock.
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
_________
#44
Sponsor
Yep, they're in stock. Just go to http://www.js2k.com to order
__________________
_________
_________
#46
subscribing...i'm gonna do a little research on where the OEM drain plug is actually located...I wanna make sure that all the oil comes out w/this thing
do you have closeup from different angles (side, under the car, etc...) that would be very helpful
#47
Sponsor
I'll take a picture of it tonight.
From their FAQ, the valve does not protrude into the oil pan, so the same amount of oil is drained as if you were stock. If you want to make extra sure to get all the oil out, you can Jack up the driver side of the car.
__________________
_________
_________
#49
Sponsor
Sorry for the confusion. Yes the first time you install the valve, you will need to jack up your car.
__________________
_________
_________
