Fumoto Oil Drain Valve - Easiest oil change ever!
#113
Sponsor
Originally Posted by jcjt,Aug 9 2009, 09:32 PM
regarding installing that, is there a specific torque? cuz... i'm not buff or anything, but my hand tight is usually tighter than some people's.
They don't provide any torque specs. They just tell you not to becareful to not overtorque the valve or adapter.
Thanks guys!
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
_________
#116
Sponsor
I don't believe so, as I believe the oil lines screw directly into the oil pan.
Thanks guys!
Thanks guys!
__________________
_________
_________
#118
Sponsor
Yep I've got some in stock. Thanks
http://www.js2k.com/index.php?main_page=pr...2898716dc053ddd
__________________
_________
_________
#120
Sponsor
I believe the valve should work with X-braces, but I do not know if it will drip on your X-brace. The point that the oil flows is about 2 inches away from the OEM drain pan (2 inches parallel to the ground, not toward the ground)
__________________
_________
_________
