Fumoto Oil Drain Valve - Easiest oil change ever!
#92
Originally Posted by DragonHeart,Aug 1 2009, 11:03 AM
This was going to be my main concern....In regards to tracking. Although I would love the convenience, I'm having trouble parting with my magnetic bolts...
Any counter arguments to the magnetic drain bolts???
#93
I think my lazy side is winning over as well. I had a magnetic drain bolt in there and i still blew my engine...
i don't think matters.. and because it's so easy to do an oil change you can change your oil more frequently, which is better for the engine than any magnetic drain bolt could be
That would be my argument!
#94
I would be interested in knowing what the drain bolt pitch and size is on the transmission drain. I stripped mine years back and would like to use one of these as a permanent addition and to ease the oil changes. It looks like numbers 16-23...
Diagram:
Majestic Parts Link:
If anybody has this information I would be much obliged
Diagram:
#95
Sponsor
Someone said a previous page that the transmission drain bolt was the same size and pitch as the oil drain bolt. The oil drain bolt is 20mm-1.5.
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
_________
#96
Originally Posted by tronvex,Jul 28 2009, 10:13 AM
I'll order mine on the next oil change which will be for a while. I would like to know if this will work for the transmission since it use the same size bolt and crush washer as the oil pan?
#97
That would be awesome to find out! Now that I installed my Fumoto valve for oil changes I'm liking the thought of being able to do the same for the transmission. I'm guessing the differential is totally out of the question?
I'd think that if the oil drain plug fit into the transmission plug hole that the Fumoto valve would work on the transmission too. But I don't want to just guess with this... Clearly someone has some solid info on this... Who to ask...
#98
Suit yourself, obviously, but what's the advantage of using the valve for the tranny or the differential? You still have to put the car on jackstands to fill them....
#99
#100
Sponsor
Sorry to digress, but here are some oil change deals for your next oil change!
Also, take $1.00 off your Oil Drain Valve with code 'Aug_09'
PepBoys Good till 8/30
5 quarts Castrol GTX conventional oil + Fram oil filter for $10.99 after $4 MIR
5 quarts Castrol GTX High Mileage oil + Fram oil filter for $16.99
5 quarts Castrol Syntec synthetic oil + Fram oil filter for $24.99
5 quarts Castrol Edge synthetic oil + Fram oil filter for $29.99
1 gallon jug Mobile 1 synthetic oil (5W30 or 10W30) for $19.98
http://forums.slickdeals.net/showthread.ph...93642&t=1460517
And more from Autozone:
New Autozone DIY oil change deals (good through 8/26)
5.28 quart jug or 5 1-quart bottles Castrol GTX conventional oil + STP oil filter for $17.99
5.28 quart jug or 5 1-quart bottles Castrol GTX high mileage oil + Bosch oil filter for $17.99
5+ quart jug or 5 1-quart bottles Quaker State conventional oil + STP oil filter for $13.99
5+ quart jug or 5 1-quart bottles Motorcraft synthetic blend oil + Motorcraft oil filter for $15.99
5 quarts Castrol Syntec Blend synthetic blend oil + Bosch oil filter for $19.99
5 quarts Castrol Edge synthetic oil + Bosch oil filter for $29.99
5+ quart jug or 5 1-quart bottles Castrol Syntec synthetic oil + K&N oil filter for $27.99
5+ quart jug or 5 1-quart bottles Mobil 1 synthetic oil + Mobil 1 oil filter for $29.99
5+ quart jug or 5 1-quart bottles Mobil 1 Extended Performance synthetic oil + Mobil 1 oil filter for $34.99
Save $2 on any in-stock air filter with the purchase of any oil change special.
http://forums.slickdeals.net/showthread.ph...93642&t=1479569
__________________
_________
_________
