Where can I install my 4.77 final drive in TO?
I'm having trouble finding a place to put my gears in..
anyone have any suggestions?
btw I didn't get the install kit.. I just have the gear and pinion.
thanks in advance
thanks in advance
Administrator
Better yet I'll trade you my 4.77 diff for your 4.10 diff + the gear set you have. Straight swap. They were installed in October by HardTopGuy and have about 3000 miles on them and are perfect. I'll even throw in a YellowBox speedometer calibrator and you save $300+ on the install kit and installation. I want to go back to 4.10s and will sell your gears to make up the difference.
When I had my 4.57R gear and pinion Speedstar was where I was going to have it installed. As mentioned above, they have done quite a few and have experience with this install. They should also be able to get you the necessary OEM Honda parts, along with the proper shims as they stock these in their shop for easy access.
www.speedstar.ca
(905)415-3442
www.speedstar.ca
(905)415-3442
HeavyRightFooT
10-18-2007 09:27 AM
