Tranny/Diff Fluid Maintenance
Where did you guys do your tranny and diff fluid maintenance? Any recommended shops? How much were you charged?
What did you use? Redline? OEM? Tks.
if you get a pump to fill the diff fluid that actually works it should take you an hour to do yourself.
the 23mm socket is like $6 from canadian tire, so get one of those and a torque wrench if you don't have one... and a socket set and use the 3/4" socket for the tranny drain and open end box wrench for the diff fill. Just make sure you get new washers. I re-used my fill ones but put new ones on for the drains
