Southern Ontario S2000 Owners Southern Ontario S2000 Owners forum including Toronto, Kitchener/Waterloo, Hamilton and surrounding area
throttle blip... almost stalling
Old 03-26-2015, 03:28 PM
Thanu31's Avatar
Default throttle blip... almost stalling
so i just did my oil change and started it up. everythng seems and sounds fine except for one thing.
when i blip the throttle while idling, it revs then almost stalls. doesnt stall but gets really close before it goes back to normal idle :/
i dont have any CELs
Anyone know what the problem may be?
Old 03-26-2015, 03:46 PM
zeroptzero's Avatar
Received 3,799 Likes on 2,677 Posts
Do an idle re-learn procedure, it should straighten out the idle.
Get the engine fully warm, then shut it off. Pull the battery cable or ecu re-set fuse for a few seconds, I always do the battery cable but either work. Reconnect battery or fuse. Make sure all of your electrical accessories are turned off - radio, ventilation, lights, drl's (pull up e-brake if you have drl's). Start up the car and let it idle for at least 5 minutes without touching the throttle at any point. Shut off the engine after 5 minutes. That should stabilize your idle setting, it just helps the ecu learn the idle air flow conditions of your engine and it can better control the IAC valve.
If the problem continues to occur into the future you may need to clean your IAC valve, but start with the idle re-set first.
Old 03-26-2015, 03:54 PM
Member
Spotter
kryptonite's Avatar
Get the engine warm, then pull the battery cable or ecu fuse for a few seconds. Reconnect battery or fuse. Make sure all of your electrical accessories are off - radio, lights, drl's (pull up e-brake if you have drl's). Start up the car and let it idle for about 5 minutes without touching the throttle at any point, then shut it off. That should stabilize your idle setting.
If it continues on into the future you may need to clean your IAC valve, but start with the idle re-set first.
Interesting first point, I was going to say the latter, but good info here
Old 03-26-2015, 03:56 PM
Thanu31's Avatar
will give it a try
Thanks!
Old 03-26-2015, 04:32 PM
starchland's Avatar
Chances are you pulled your battery over winter? Problem should straighten itself out
Thanu31's Avatar
Thank you so much jfusion! All good now
I worry too quick lol
Old 03-26-2015, 06:17 PM
Thanu31's Avatar
Yea I did, thanks
Old 03-26-2015, 07:34 PM
Ying19's Avatar
good to know! I've been having that issue last year as well when coming to a stop.
Old 03-31-2015, 07:47 PM
BummyTime's Avatar
I did this and it worked thanks but now my radio needs a code FML
Old 03-31-2015, 09:04 PM
Member
Spotter
kryptonite's Avatar
If you have your manual it might be stuck in there. Mine was stuck on the inside of my trunk
If not, give Honda a call, they'll give it to you
Quick Reply: throttle blip... almost stalling
