Suspension question
#26
Originally Posted by PLYRS 3,Mar 7 2006, 03:40 PM
you got 'em?
The KG/MMs are a little stiff the KW's seemed more compliant.
#27
you got 'em?
I like them. They are a good track/street car setup. If you want pure track performance you would probably want to step up to the $5k coilovers. Stiffer springs, less roll, but the damping makes it feel almost as comfortable as stock. Good travel on the suspension, makes it good over bumps. There is better feel in the transitions, you can really feel the tires loading up in turns. Quicker turn-in and there is more fiddle room for controlling the oversteer. I haven't spent a lot of time spinning the adjustments, but the adjustments do change the ride. It's a pain to adjust the compression though, since it is at the bottom of the shock.
I've got rear anti-bumpsteer control arms, a bigger front swaybar and modified wheel alignment. Not sure the "improvement" from stock, but it is definitely better.
#29
Originally Posted by s2k_b,Mar 4 2006, 06:53 AM
What suspension do you guys use? cause I am thinking to lower my ride but don't know too much about S2K can someone give me some opinion.
Thanks
Thanks
The stock suspension is very good.
