Southern Ontario S2000 Owners Southern Ontario S2000 Owners forum including Toronto, Kitchener/Waterloo, Hamilton and surrounding area
S2000 OIL PRESSURE/ ENGINE NOISE PROBLEM
Old 04-09-2008, 11:04 PM
Jagga_s2k's Avatar
Smile S2000 OIL PRESSURE/ ENGINE NOISE PROBLEM
hey im new to this whole s2000 thing so im driving i hear werid noise from my motor when im reving around 4000 rpm and up when i low down at the lights at a stop i get the oil pressure light but the noise is driving me nuts there enough oil in the car and everything... anyone know what this could be the noise sounds like something grinding or rattling.. thanks
Old 04-10-2008, 04:05 AM
iDomN8U's Avatar
drive the car easy or if possible not at all, this could be a serious issue.
I would try to get a reading on your oil pressure, what type of oil is in there?
Post this in the Under the Hood section
Old 04-10-2008, 05:19 AM
chowbj's Avatar
what is the noise like? are you at a stop and reving? or is this while your driving at 4k rpm (what speeds). also what oil are you using?
Old 04-10-2008, 05:30 AM
Jagga_s2k's Avatar
moble 1 10w30 its only when im driving at higher rpms
Old 04-10-2008, 07:24 AM
iDomN8U's Avatar
If you have a oil pressure issue, you could cause some serious engine damage.
I would have this looked after at a Honda dealer
Old 04-10-2008, 07:41 AM
paul__chen's Avatar
the oil light coming on isn't good
you should stop driving the car and get it diagnosed/towed
Old 04-10-2008, 08:01 AM
s2kobsession's Avatar
check out those banjo bolts... they could be half clogged and starving your engine of oili intermittently. Very very common problem on ap1's
Old 04-10-2008, 02:33 PM
Jagga_s2k's Avatar
banjo bolts? im new to this
Old 04-10-2008, 03:31 PM
aka oil jet bolts.
You will find in ap1's that 50% kabooms are from mechanical over-rev, 45% from oil jet bolts clogging and 5% from other
Old 04-11-2008, 05:34 AM
chowbj's Avatar
Keep us posted OP. I've beening thinking about switching up my banjos, but whated to see how and who can handle here.
Quick Reply: S2000 OIL PRESSURE/ ENGINE NOISE PROBLEM
