noise! URGGHHH
noise! URGGHHH
i have this noise that comes from front passanger side area around the wheel its like a sqeeking noise or something loose that is just hitting against something, u can only hear it when the car is slow and is going over bumpy rd or a bump what is it!! i dont think its my wheel bearings or anything to do with my wheels cus when i try to move my wheels they dont move.
I had a similar squeak, put up with it for a day or 2 and decided it was time to take a look. At first I thought it may have been my coil-over going (check this for oil leaks) and make sure your spring is seated correctly.
Mine was okay so I took the wheel off and tightened all of the suspension bolts with my torque wrench. When I got to the drivers side toe adjustment I found it was loose and causing the squeaking.
In my case the alignment shop failed to tighten it, if you just had an alignment it could be a suspect. Good Luck !
yea i did have a similar problem but then it went away and now its back and i cant stand it lol... i will be checking the all the nuts and bolts around the suspencion
vtec9
07-21-2014 08:03 AM
