Need Help: Passenger side power window failure...?
hey guys
My 03 S2000's passenger side window suddenly just stopped working.
In detail, the switch on the passenger side doesn't work either up or down, but the switch on the driver side can roll it UP but NOT down
when I fold the top down, it DOES go down though.
Driver side is working just fine.
I've checked the window lock switch.
it's really strange, i've done some research myself but no luck so far
Anyone had a similar problem??
I really could use some help guys
Thanks
Thanks
I have had passenger window problems in the past as well.
I took the drivers door apart and there is a control box in there.
I found water had made it's way into the module and started to corrode the circuit board inside.
After cleaning off the corrosion and letting the box dry out I put everything back in and it worked.
You may want to look there first, but there are quite a few things to check out as well.
Good luck, after researching this problem a few years ago I know there is fcuk all info out there.
sexysilvers2000
09-04-2018 04:01 PM
