My S2k Dyno run!
My S2k Dyno run!
Ok so I just put my 2003 S2k on the dyno and had them run it up to 8700rpm. My first run was 187whp and 132 torque, 2nd run 190whp and 135 torque. I was running 12.45 AFR all the way along, they said I am rich and would be fine for boost but since I am not I can lean it out and make more powa.
I was bang on what I though it was going to be for torque and around the same area for HP.
All it's got is AEM intake, HKS exhaust, AC delete. Do these numbers seem to be pretty acurate??
My link
My link
those numbers seem kinda low i think... i dynoed at 202 whp with exhaust, intake and header on a low reading dyno and 215 whp tuned. It all depends on the dyno though, some read higher then others. What dyno was it?
http://www.youtube.com/watch?v=gqOEBVjPDh8
thats mine
thats mine
I don't think you are running all that rich, max. power is usually around 12.7 a/f , you aren't that much more rich than that level, maybe just a tad. 190 whp seems decent, but every dyno is different, I always like running in 3rd gear myself, less load on the engine and the run goes quicker. In theory the gearing is not supposed to factor into the numbers but I always found 3rd gear produced better numbers, fwiw.
Unless you have multiple s2000's running on the same dyno, the same day, you really can't compare numbers.
what you should be looking for is have a base # and then tune and seeing the results
I am going to see what a street tune would run me.... As of now the wife don't know I had it dynoed at all Lol I figured 190whp was pretty decent since it's 227 at the crank so thats an 18hp loss over 8 yrs... I am not much of an engine guy at all! So this is all new to me but I wan't to learn how to get more power without boost!
Like Cleans2000 stated, NA hp is crazy expensive on this car, somewhere in the range of $100-$300 per hp, either go boost or stick with oem or minor bolt ons at the most, unless you have a lot of money to throw at it.
