Southern Ontario S2000 Owners Southern Ontario S2000 Owners forum including Toronto, Kitchener/Waterloo, Hamilton and surrounding area
My cavalier has a problem, any ideas?
Old 05-11-2013, 12:36 PM
FluKy15's Avatar
Default My cavalier has a problem, any ideas?
While im driving on the highway at 90 its fine. As soon as i go to 110 or higher my coolant temp goes up. Normally it runs dead on 90c, when i go above 110 it heats up to 95c, and when i go 130 it heats up to about 100c-105c. As soon as i slow down to 90 it goes back to normal temp. Previously it always held at 90. It went low coolant recently and so i filled it. Thats the only thing i can think of that i have changed. Could it actually be the coolant i used?
Old 05-11-2013, 02:28 PM
C63AMG's Avatar
It could be a number of issues but my guess is either an air pocket in the system or a blockage in the rad.
Old 05-11-2013, 03:09 PM
FluKy15's Avatar
Ok so how do I get rid of the air bubbles? Not something I have done before.
Old 05-11-2013, 04:34 PM
C63AMG's Avatar
Depends how the system is designed. There will be a bleed valve. I'm sure you could find a wirteup somewhere.
Old 05-11-2013, 06:18 PM
s2kobsession's Avatar
ya i'm betting it's a air pocket in the system....
check youtube for a video!
Old 05-12-2013, 06:53 AM
s2kt3's Avatar
Water pump leak ..... Coolant low indicates its getting out some how.... Maybe head gasket damage was done.
Or maybe a cavalier wasn't meant to go 130
As speed goes up so does engine speed, the system can't keep up. Cheap thing to try first make sure there are no leaks, second put in 1 little bottle of water wetter ......
Old 05-12-2013, 07:19 AM
FluKy15's Avatar
The worst case scenario I was thinking was head gasket
I used to run the car at 130-135 for an hour or more, it stayed dead on 90c the whole time. It started after I added coolant, which has me wonder. Gonna start checking for leaks, but I hadnt noticed anything before. I have had the car a year and a half, and only have done oil changes. I did no other maintenance to the car whatsoever, not even add windshield washer fluid
Old 05-12-2013, 07:46 AM
Holeecow's Avatar
Had a sentra with similar problems.
It was head gasket.
But specifically when they filled up the coolant again. They had to jack up the front so there wasn't any air pockets.
That might help out?
Old 05-12-2013, 11:39 AM
s2kt3's Avatar
I have a pressure tester... Lmk, we make fix (Russian accent)
Old 05-12-2013, 07:05 PM
FluKy15's Avatar
Are you going to the wednesday night meet?
Quick Reply: My cavalier has a problem, any ideas?
