Leakdown Test on a Cold Engine - Seller Says this is Useless?
So I bought a motor off Sonshine Autoparts and had my shop do a leakdown test on this engine.
The results: 88% leakage on cylinders 1 and 2, 55% leak on cylinder 3, 20% leak on cylinder 4.
Obviously this is terrible so the shop advised me to send it back, which I did.
Ultimately, here was Sonshine Autoparts' reply after they received it back. I'm not sure what to make of it, can you guys comment?
I won't go into a pissing match with your mechanics but after assisting in the diagnostics of this engine,right off the bat my guys questioned a leak down test on a cold engine ,they explained to me that engine cylinders are never perfectly round but oblong to compensate for heat expansion therefore you would never be able to get a properly sealed engine when its cold.
Feel free to contact me for further explanations
Thank you
Don Laniel
dlaniel@sonshineautoparts.com
Thank you
Don Laniel
That's exactly what I thought too. This is not my field but common sense tells me that if what he was saying was true it should be reasonably symmetric across the cylinders.
How long has it been since the motor ran? Could this be the issue on a cold test?
I think they should run the engine and see if there are any issues. It's a swap but simple enough. I'm curious to hear.
Correct about the leakdown being done in operating temparures only, never cold. Also if the numbers were that far off I'm pretty sure you'd have a pretty sure you'd have a pretty bad idle in some sort of way to say the least.
RabidRat
10-11-2011 11:21 AM
