Southern Ontario S2000 Owners Southern Ontario S2000 Owners forum including Toronto, Kitchener/Waterloo, Hamilton and surrounding area
Kg/mm Spring question for owners....
Old 07-29-2004 | 03:15 PM
wing's Avatar
Default Kg/mm Spring question for owners....
How the hell do you work on your car???? Rob?
The freakin' lifts at the dealer are too high to fit under the car, so we had to drive it up on a ramp then jack it
If I wanted to do some serious rear end work or something it would be a serious pain.
Love the drop though
Old 07-29-2004 | 04:19 PM
toosteeley's Avatar
So far, I do all my matience myself. All I do is either drive the car onto boards, or lift it an inch or so with the spare tire jack, then slip my big jack in.
The S is pretty low to begin with. Another 1.5" makes it a bit challenging
Old 07-29-2004 | 04:42 PM
QIKSILVR's Avatar
Yup, the stock height won't allow me to use the big jack either.. Need to use the OEM jack first.
Old 07-29-2004 | 06:00 PM
Donb's Avatar
I keep some boards around just so I don't have to fight with the OEM jack. Works for me
Old 07-29-2004 | 06:18 PM
Jasonoff's Avatar
Banned
Make 4 ramps out of 2x10 spruce.
You need 2 10' 2x10's. Cut 4 at 3' and 4 at 2' 45 the ends and glue/screw them together. Use a 3" screw and countersink 1/4".
Done!
Old 07-30-2004 | 04:21 AM
PLYRS 3's Avatar
you must work at home depot....
Old 07-30-2004 | 04:51 AM
wing's Avatar
OWNED... hehehe.
Right now I use some pieces of scrap MDF I have laying around. At the dealership though I didn't have them obviously so it was a pain, they found a wheel block and I drove onto it.
I should make something but it's still a pain. Changing the diff fluid it said to have the car level! Well I couldn't jack it up then because it wasn't level. I suppose I could have jacked up the entire car, but that seemed like a pain as well.
Old 07-30-2004 | 04:53 AM
wing's Avatar
Wait a minute ..... I'm confused on your "ramps"
How they going to stand up? Hmmm
Old 07-30-2004 | 05:01 AM
Jasonoff's Avatar
Banned
Did... and the wood was free when i made them
Old 07-30-2004 | 05:05 AM
BioBanker's Avatar
just get a really good run at the hoist; itll clear the arms if you get up to a good clip....
Quick Reply: Kg/mm Spring question for owners....
