Southern Ontario S2000 Owners Southern Ontario S2000 Owners forum including Toronto, Kitchener/Waterloo, Hamilton and surrounding area
First Time Lapping Questions
Old 08-22-2007 | 06:21 AM
Triple-H's Avatar
Originally Posted by cthree,Aug 21 2007, 05:26 PM
Please see the Racing and Competition forum. There are lots of answers there.
Yes, and then all they will say is do a search...
Old 08-22-2007 | 06:26 AM
Triple-H's Avatar
[QUOTE=iDomN8U,Aug 22 2007, 09:18 AM] I don't understand why motorcycle helmets wouldn't be allowed, they are the most compliant helmets.
Old 08-22-2007 | 09:48 AM
THEOLDMAN's Avatar
Motorcycle helmets are basically rated for single impact in a single event, while an SA helmet is tested for multiple impacts from a single event.
Old 08-22-2007 | 10:36 AM
Triple-H's Avatar
Because you probabley won't live to the 2nd impact...
Old 08-22-2007 | 05:40 PM
LauraC's Avatar
Mostly everything about your car has been said... Bfluid and oil. Bring some oil with you just incase you're burning oil. Don't forget to check your oil between sessions and check you air pressures.
Also get a good nights sleep and bring lots of water and fruit. Keep yourself hydrated and your body fed. Its tiring being focused on the car and the track.
Old 08-24-2007 | 11:06 AM
s2knewbie1's Avatar
Thanks for the help everyone!
Old 08-28-2007 | 05:28 AM
Fuggles's Avatar
How likely is it that I will burn through a set of brake pads? I would like to attend my first lapping day soon but don't have the first clue how to change brake pads myself, let alone at the side of a race track. If I had my brakes inspected by Speedstar prior to an event, should that be enough insurance that I would have enough brakes to drive home on?
Old 08-28-2007 | 05:34 AM
iDomN8U's Avatar
Take your tire off and inspect the amount of brake pad.. Make sure you put back the tires and torque to spec (I like 90 lbs)
Old 08-28-2007 | 08:29 AM
matrix's Avatar
Yes - Speedstar can tell you if you have enough. If you are new to lapping, you don't need to worry about going through pads unless you have next to nothing left anyway.
smokenrowboy
09-03-2009 11:09 AM
J's_Racer
05-23-2007 06:32 PM
Baby_Lexx
03-28-2007 02:24 AM
cbender
09-20-2002 07:02 PM
honda_s2k
06-26-2001 03:30 PM
Quick Reply: First Time Lapping Questions
