Doin my own oil change
I've got that maintenance flashy button on my dash and i have been tolds that it means i need to have an oil change. Is this right? If so i plan to do my own oil change on the weekend but i would like to know where the reset button is for the computer so i can get rid of this annoying maintenance light that flashes every time i start my car. Thank god it goes away after about 3 seconds.
Thanks in advance
Thanks in advance
Check under the hood forum, it will eventually no longer go away.
It's something like, hold the trip and the other button beside it and turn the key on that resets it. Something like that.
1 Post
You should write down when you do oil changes so you know when they are due. If the car is new to you, you should just do an oil change and start fresh. Just because the light is blinking does not mean an oil change is due. If the warning light was not reset at the proper time it is possible to be due for an oil change and not have the light blinking, or not need an oil change when the light is blinking...
Sorry, I can't remember how to reset it, I look it up in the manual each time it comes on because I do not use it for any kind of maintanence reminder.
Thanks guys, i think i'm going to change all my fluids this weekend as i have no idea how long it's been. i kinda boubt the diff fluis has ever been changed. At least i'll know and have some piece of mind if i do it as opposed to just assuming it has been.
