clutch,syncro tsb?
I haven't had mine done yet but honda told me all a tsb allows them to do is check for the problem. If they check it and they don't see anything wrong, nothing will be done. If there is a problem it should be fixed at no charge.
The clutch TSB is for a rattling clutch disc. The disc springs has a "resonance" vibration that is irritating to some owners. It is NOT a mechanical problem, just annoying. I've had this rattle since day one and dedided not to get it fixed as many have reported that the noise eventually comes back even with the TSB done. The car's performance does not suffer.
The synchro TSB is only if you have a consistent and duplicatable grind when shifting and can be determined NOT to be related to clutch operation and adjustment.
